moammadhasan
Newbie
hi all!
I'm gonna use Monte Carlo Analysis to find standard deviation for input Offset of a latched Comparator using icfb 5.10.41_USR5.90.69. the goal is to plot it against a voltage value called Common Mode Voltage. It is to some extent a parametric Monte Carlo analysis. But it seams this version cant sweep any parameter. It is as if I need to run the "tools> Parametric Analysis" of "ADE" for Monte Carlo!!! would anyone help?
the other question is that: what does "stddev" function ADE Calculator really do?!! when I use tsmc 0.18rf Library file for mismatched models of the Mosfets, I found this "stddev" calculates some standard deviation for any node voltage without Mont Carlo or even some Parametric Analysis. Is it reasonable? "stddev" even calculated standard deviation over the swept voltage mentioned above, i.e standard deviation over a voltage instead of iterations!!!!! what does it mean?
sorry for my weak English & thanks a lot for any response......
