Parameterized bitwidth
promach
Code Verilog - [expand]
parameter C_PCI_DATA_WIDTH =128;
rData <= #1 (rData << 4) - (C_PCI_DATA_WIDTH)'h0014001400140014;    // implements 16*x*x-20 for four different pieces of 32-bit data
How should we solve the syntax error around (C_PCI_DATA_WIDTH)'h0014001400140014 ??
First, this doesn't look to be parameterized.
Second, the comment is wrong unless there is a specific set of assumptions on the inputs.
Third, if such assumptions exist it is much better to write the code in a way the tools can use them.
for example, this is a 128 bit add (maybe, it looks like you are using 4 16 bit values which is 64b). It isn't clear that this never overflows/underflows into other 32b values.
I think you want to use for-generate with [32*myGenvar +: 32].
You didn't show the declaration of rData, but you may be able to just write:
rData <= #1 (rData << 4) - 'h0014001400140014;
Otherwise you can write
typedef bit [C_PCI_DATA_WIDTH-1:0] PCI_DATA_t;
rData <= #1 (rData << 4) - PCI_DATA_t'('h0014001400140014);
