midohamaki
Newbie level 5
Help on parallel port Pulse Rate monitoring
hii guys
i dunno if that where i should post my problem ,,,
i wanna to monitor my parallel port pulse rate which dont work with my l297 chip and
i used 555 timer and worked well in range from 100 Hz To 400Hz but the parallel port did not work with doing all setup correctly
with out any oscilloscope instrument and if it's hard to be checked with parallel port .....
how can i check the rate of signal pulses at any control pin ..
thanks
hii guys
thanks
