vsmGuy
Advanced Member level 2
74ls245 breakout board schematic
Hi
What do you think about putting 10K pullups on DATA port and 1K Pullups on STATUS and CONTROL port of DB25 Parallel port connector ?
I intend to use the SPP mode of the Parallel Port(with Output capibility and DATA, and normal direction of CONTROL and STATUS port).
Will this be OK ? Or should I change the resistor values ?
Hi
