parallel db25 and isp programmer
ronzam2002
Member level 5
Member level 5
san juan
Is the circuit of isp programmer is the same with the circuit of parallel db25 connector which is used for interfacing pc to printer?
Here is a circuit of isp programmer.
Yes, you have to connect this cable to the 25 pin PC parallel port connector normally used to connect to a printer.
Regards,
Laktronics
In figure below, is this paralled db25 connector can be used for interfacing at89s52 board to pc?
You have to use a 25 pin DB25 male connector as shown in your picture at one end of the cable, which will be plugged into the printer port of PC,which is normally a DB25 female connector. You should wire up the circuit shown in your earlier diagram as part of the cable. Inorder to connect the cable to 89S52 board, you need not use a DB25 connector, instead you can use a simple 6 pin connector. By doing so, you can also avoid the possibility of connecting the wrong end to PC.
The picture shown is a bit confusing since it looks like a simple cable with DB25 male connectors at both ends and it does not show where the circuit components are assembled.
Regards,
Laktronics
That cable in the figure is just for interfacing pc to printer.
Well, does the cable of the parallel db25 have 6 wires inside? I'll just cut the other end of the cable and connect the cut end to the mcu board..
Standard parallel port cable will have many more wires, eg. 8 Nos for data bits, Ack, Busy , ground and so on. You have to use only specific five wires (including ground)shown in your circuit. Vcc is from your board. If you are mounting the AND gate as a part of your board, you can just connect these five wires to your board directly and be done with it.
Regards,
Laktronics
P.S.
Standard printer cable does not have any logic circuit as a part of it. It has only simple wires connected between pins. If you mount the logic circuit of your programmer cable on your S52 PCB, you can also use cable having only few wires, but it will not be an ISP cable in the true sense. People therefore mount this logic as a part of the cable, inside the hood of the connector.
Laktronics
