Well, where do I begin?
18 Ghz is a pretty high frequency. Your bandwidth is pretty small (<0.1 GHz). So you are going to have a whole bunch of practical implementation problems.
Suppose that you use an alumina substrate for a microstrip filter. If you simulate it properly, you will probably see that the predicted insertion loss will be on the order of 2 to 4 dB for a multisection filter. So the choice of ripple factor is not really all that important.
In engineering one designs to specifications. If your customer (or teacher) has not given you specifications, then you must postulate your own specifications, design to them, and see if your design makes sense.
Lets say that you want low loss from 18.5 to 18.6 GHz. You might figure out that the εr of alumina is not well controlled, perhaps +/- 0.2. You also know that you can not hold tight etch tolerances of the final artwork, for a student you might get processing as good as +/- 0.5 mils. So the first step is to design a "guard band" around you filter to take into account these two factors. You perhaps need to design a filter that has low loss from 18.4 to 18.7 GHz, or even broader!
Once you have figured that you, if there is no rejection requirement, pick an easy N number (like 3 or 5) and go ahead and design the filter. When you have the physically predicted dimensions, sketch it out to scale and see if the dimensions make sense. Do you have 10 mil wide resonators, but they are space 40 mils apart? Then you are going to have a lot of stray coupling, and the packaging is going to be a major part of the performance.
For such a high frequency, and such a narrow bandwidth, it would be good to take your final design and pass it through an emag simulator program to get a better prediction of the performance.
