Hasan2017
Member level 4
Hi There,
I got a part of vacuam cleaner machine driven by DC charger. May be it was manufactured in 2018.
User might through it away because it was troubling.
9 pcs of P-130SCS 1.2V 1300mAh has joined togeter to get 1.2×9 Vdc.
https://www.digikey.in/product-detail/en/panasonic-bsg/P-130SCS-A06/P162-ND/530492
Basically it was using for drive a 9 v DC motor. Manufacturer recommended to plug it with 9V/300mA charger for use it 8 hrs, may be charging time was for 15 mins.
1. Does it risky to use this battery after a long time?
2.It may damaged?
3. How can I charge it with another way?
4. Take a look the charging and discharing circuit and battery bundle.
Recommend me any safe mode charing topology or particular circuit.
Hope you will help
2.It may damaged?
Hope you will help
