PADS net List Errors
pdi_eng
I am pretty new to PADs and have a few issues that I can't figure out. I am working in version 9.1.
I am adding a few components to an existing design and when I push the Netlist to the PCB I get errors:
"Power or Ground Symbols used with wrong Net Name"
"Subnets with Missing Off-Page Reference"
"Subnets with Off-Page Reference to no other Subnet"
I have attached the error log.
Do the errors matter and what can cause these errors?
  • padsnet.err.txt
Hi
For 3.3 V power symbol used for 5v so remove it. please check the symbol location
For a design with multiple supplies, can you only use the power symbol for one of the power nets? Is there more than one power symbol somewhere?
Thanks for the reply!!!!
You can edit library part decal of the symbol and add CAE decal for required net name (you need also then update scheme from library). But I am extremely unsatisfyed with this solution, because of signal names are not general valid but absolutly design specific. So I would need to dismiss this stupidus check.
