PADS Layout - Same Net Clearance does not work
flypeyton
Newbie level 5
Newbie level 5
I want to separate some power ground traces from the ground plane when doing pouring. In the design rule, I selected "net" and chose the "gnd" net and set the same net clearance of "trace" to 0.2mm. But when doing pouring, the ground traces are still covered by the ground plane.
In Allegro or Altium, it is much easier to set the same net clearance of "trace" to "plane". Any idea how to do it in PADS Layout?
I never used PADS Layout, but I had the same issue in Eagle. What I did was to put a restrict layer above the GND signal which I wanted to be separate the GND plane.
