Pads design of new pcb library
Vraj
Full Member level 1
I am making new pcb library.
Is C1 and C2 are really necessary for pads design?
If I made square pads, then would it cause problem for reflow soldering?
Thanks
No, having a chamfer on the corners of the IC does not mean you have to do that to the pads.
Plain rectangular pads work fine, bullet shape pads work fine.
Square pads? I'd do them rectangular not square.
Reactions: Vraj
    Vraj
Yes, rectangular pads *
Make a rectangular pad at least L x b for each pad. A better pad would be L + 0.004" by b + 0.004", with the resist opening L x b. You can radius the inside part of the pad if you desire, but it is not necessary. With modern PCB tools, you can make any geometry pad that you want.
Reactions: Vraj
    Vraj
The drawing that is presented in the datasheet is not always the recommended dimensions for the footprint, but often represent the dimensions of the component itself, therefore you should extend a little the land patterns on this case. Consider the fact that according to current standards, for the same component it is possible to draw slightly different footprints optimized for distinct assembling processes, or rather, the same footprint with varying margins.
Reactions: Vraj
    Vraj
This is AV connector( RCA Jack).
Problem is height.
The top side of this around 13.2mm from the pcb.
My plastic model will be made of PLA or ABS material having 1.5mm thickness.
So, total height is 13.2+1.5=14.7mm from pcb.
My switch is having 14mm height from pcb.
So, should I reduce the thickness of model and/or I reduce height by doing this:question3.png?
I will push Av connector little outside of pcb so that the block will on outside of pcb.
Will this cause any problem?
I will change pcb hole only size for av connector.
I found I can reduce size by 1.4mm (by scaling image and measuring distance).
Switch head will 0.8mm from case[14-(13.1+1.5-1.4)]=0.8mm.
Is it good enough distance for pushing switch ?
Thanks
From my experience: doing non standard assembling (of your RCA jack) is likely to prduce problems.
Therefore I recommend to keep on standards.
* use a different RCA jack or use a different push button
Check if there is an improvement when the RCA jack and push button are be mounted on opposite sides of the PCB.
Klaus
Reactions: Vraj
    Vraj
