Yes it is checked andre!
But I found it!
I knew that I should check "pad hole" and "via hole" somewhere to make them visible.
I had looked at View Configuration several times before but I couldn't find them.
After you referred me to this panel again I found their locations accidentally.
They were collapsed under "system colors" as shown in picture below
As I click on it the picture below appears and I can check them
