p10 led module interface with pic
raman00084
Full Member level 6
Full Member level 6
i want to interface p10 single colour led module 16x32 with pic micro. any sample code kindly help
i cannot get the schematic for p10 if any one have kindly send.
how much io will p10 led module need with pic
Thank you. If i am using 4 modules then also the io will be 6?
Without knowing anything about your module...I assume you need individual OE for each module.
OE, or better say CS will be low-active.
A 74HC138 (or similar) may reduce microcontroller pins and additionally avoid that accidentally two or more modules can be selected at the same time.
Klaus
no need more io for 4 module OE,STB,CLK,A,B are parallel and data is in cascade mode
P10 module is 1/4 scanning (4 ROW SCAN ONE TIME)
PIN A B
0 0 ROW 1,5,9,13
1 0 ROW 2,6,10,14
0 1 ROW 3,7,11,15
1 1 ROW 4,8,12,16
