ayeong
Full Member level 1
common source mosfet battery
I have encountered a circuit whereby I could not understand how does it suppose to work.
There are 2 similar P-Channel MOSFET (Vishay Si1413) which I shall termed it as Q12 & Q15.
Both MOSFET have their gate connected to a single control point which means if a low is applied, both MOSFET will be turned on.
Drain of Q12 : DC supply from AC/DC adapter
Drain of Q15 : DC supply from the battery
Both MOSFET's gate will be LOW whenever the user depress the start button which will result in both MOSFET to turn ON.
What I do not understand how would Q12 & Q15 work together to PREVENT the adapter DC supply from charging the battery and yet allow the DC supply from battery to supply to the circuit in the absence of a adapter supply.
Anybody can help ?
Thanks
Anybody can help ?
Thanks
