sorry , but the file damagedAttached is a discrete driver for the big PMOSes you have (4 in parallel). I have simulated it for a similar big FET as yours, specifically the IRF7210 (it has higher total gate charge than the one you use).
Also, the layout is very important. Keep all gate traces and gate drive areas small. Add decoupling capacitors.
I wonder which node voltage is shown in the waveform?Your waveform suggests something is not connected correctly, or a component is damaged...
