Overvoltaging a capacitor critical or not ?
thebadtall
Full Member level 6
Full Member level 6
Hellas
Hello, Im working on a LM317 voltage regulator !
after rectifier from 230 to 12v I use a 4700/16v capacitor.
The output voltage I want to be 10.2 volt.
My question is : Can I use a 4700uf / 10v ? Or it needs to be at least 16v ?
What will happen if I use 10v instead of 16v ?
Thank you
Capacitor rated voltage always should be at least twice as working voltage by default if we whant quality of product and reliability.
This capacitor rated at 16V will do the job, at 10V its on edge, and you risk life and health of 4700uF capacitor.
I will use 25V not lower. :wink:
Also load/consumer will suffer if that output filter capacitor goes down.
Among other things LM317 IC needs filtering capacitors to make factory guaranteed voltage according to datasheet.
I dont think that you need 4700uF for this circuit LM317 can provide up to 1,5A in best way, and about 1000uF per 1A is needed. 2200uF will be enough for this circuit.
Before add one more 100nF (0,1uF) if LM317 is far from first filter capacitor.
Also one more, and one big thing input voltage for LM317 should be at least 3V higher then output voltage, LM317 is not LDO voltage regulator. If you dont respect that you will get on output some unregulated and unwanted voltage.
If you've ever seen an exploding capacitor, you don't want to go there.. (well, at least it will be "memorable" ; )
This was a nice video - 8 minutes of exploded capacitor footage, I am sure many people have had similar experiences. After that, one always takes care in capacitor selection : )
