Jan 24, 2016 #1 J Jester Full Member level 6 Joined Aug 18, 2012 Messages 377 Helped 7 Reputation 14 Reaction score 7 Trophy points 1,298 Location . Activity points 4,754 I want to add over voltage protection to a 5.2V, 2.5A SMPS. I'm looking for minimum parts count and cost, the circuit could be a one time only type circuit. This device would be ideal if it had a slightly higher current rating: https://www.digikey.ca/product-detail/en/NCP349MNAETBG/NCP349MNAETBGOSCT-ND/3462393 There is a higher current variety in this family, however the 5V, 3A version does not appear to be stocked anywhere. Any suggestions?
Jan 24, 2016 #2 T treez Guest analog devices or maxim may do something, even linear.com Otherwise just use a res divider, comparator, and p channel fet
Jan 24, 2016 #3 V Vbase Full Member level 6 Joined Apr 7, 2015 Messages 373 Helped 75 Reputation 150 Reaction score 75 Trophy points 28 Activity points 2,036 You can use TL431, it's a comparator with a ref zener. You will also need P chnl mosfet and 2 resistors to set the voltage.
Jan 25, 2016 #4 T treez Guest yes, indeed, or indeed the TLV431 which has a lower ref voltage and less bias current draw. However, the bias current can be a problem as if the cct isn't done right then youll end up with the pfet on when you don't want it on,
Jan 27, 2016 #5 bowman1710 Full Member level 3 Joined Nov 8, 2014 Messages 183 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 1,604 Have you tried looking at these? http://cds.linear.com/docs/en/datasheet/1696fb.pdf http://www.linear.com/parametric/Su...8,2217,1031,1153,1367,1043,1132!s_1367,1!gtd_
Jan 27, 2016 #6 J Jester Full Member level 6 Joined Aug 18, 2012 Messages 377 Helped 7 Reputation 14 Reaction score 7 Trophy points 1,298 Location . Activity points 4,754 bowman1710 said: Have you tried looking at these? http://cds.linear.com/docs/en/datasheet/1696fb.pdf http://www.linear.com/parametric/Su...8,2217,1031,1153,1367,1043,1132!s_1367,1!gtd_ Click to expand... I did, however this might be a better solution (<$1): http://www.ti.com/lit/ds/symlink/tps25200.pdf
