Projetos_afg
Junior Member level 3
- Joined
- Feb 3, 2010
- Messages
- 28
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,293
- Location
- São Paulo, Brazil.
- Activity points
- 1,428
I'm have been trying to write an code in C++ by using the Win32 API to communicate through the RS232 serial port with equipment. It's a simplex communication (only the equipment sends data in blocks of 289 bytes). I'm using an dedicated thread to read the serial port. Firstly I tried to use non-overlapped communication, but I realized that is impossible to close the serial port if there's no data incoming (the thread gets stuck on WaitCommEvent function). So I tried to use overlapped I/O and WaitForMultipleObjects to solve this problem:
I use the function SetEvent(SerialEvents[1]); to close serial port on the main thread.
To open the serial port:
The problem is that even if I recive the 289 bytes, the thread keeps wating the function "WaitForMultipleObjects" return. If I recive the next 289 bytes the WaitForMultipleObjects function returns, but the data are mixed.
Someone could help me?
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 void *SerialRead(void *param) // param is a dummy pointer { OVERLAPPED overlapped; memset( &overlapped, 0, sizeof(overlapped) ); overlapped.hEvent = CreateEvent( NULL, TRUE, FALSE, NULL ); SerialEvents[0] = overlapped.hEvent; ReadFile(SerialPort, SerialBuffer, 289, &dwBytesRead, &overlapped);//Try to read 289 bytes while (WaitForMultipleObjects(2, SerialEvents, false, INFINITE) == WAIT_OBJECT_0) //Wait for some event, if is an serial port event, executes de loop, if not, exit. { //... //Do stuff ReadFile(SerialPort, SerialBuffer, 289, &dwBytesRead, &overlapped); //Attempt to read the next 289 bytes } ClosePort(); return 0; }
Code C++ - [expand] 1 2 3 4 5 6 7 8 SerialPort = CreateFile(PortName, GENERIC_READ|GENERIC_WRITE,//access ( read and write) 0, //(share) 0:cannot share the COM port 0, //security (None) OPEN_EXISTING,// creation : open_existing FILE_FLAG_OVERLAPPED, // overlapped I/O 0// no templates file for COM port... );
