Rajinder1268
Full Member level 3
Hi all,
I need some advice. I have a circuit that has a 3A fuse, this is to protect a supply line of 14V.
The 14V is then supplying power to a IC. The IC has a current rating of 1A. This device is being damaged, presumably by over current. The 3A fuse does not blow.
I have looked at using a TVS diode for over current protection. However, looking at a datasheet the clamping voltage current Ipp is usually greater than 3A. Do I need to add a resistor to manage the current to an acceptable level before the TVS diode?
Also is the TVS diode a good option for this application?
Best regards
Best regards
