shaiko
Advanced Member level 5
Hello,
Unfortunately, I just found out that the Xilinx FIFO generator is limited to (no more than) 8:1 ratio when an asymmetric width FIFO is implemented.
I can design a wrapper around a 1:1 ratio FIFO and achieve the same functionality with an FSM and a shift register - but before I do so, I'd like to consult the forum...
Have you come across this limitation ?
How did you solve it ?
