skywalker898
Member level 1
- Joined
- Jan 31, 2012
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Madison, WI
- Activity points
- 1,622
Hi, could a series diode be used to protect a power supply from a high voltage arc between electrodes in a vacuum chamber?
In the attached circuit, what would happen if the 80kV Target electrode arced to the 20kV Anode electrode? It looks like the 20kV power supply V2 would be protected, but I don't understand what would happen to the Anode electrode. If current cant flow through D1, then an arc between Target and Anode should bring the Anode electrode up to 80kV. The arc probably wouldn't be sustained because current can't flow, but there would be an initial transient as the two electrodes are brought to the same voltage. Then the arc stops. But then is the Anode electrode just going to float at 80kV after the arc event because it's in a vacuum chamber and the diode D1 prevent charge equalization? (apart from a small leakage current on the diode D1). Am I correct in this interpretation of what would happen?
The same question applies to using D2 to protect V3 from V2.
This next circuit has two MOV's to ensure that the overvoltage arc causes current to be routed to ground. The idea here is that the diode protect the power supplies from the immediate transient overvoltage, and the MOV activates after a very short delay to route the current to ground. With the MOV, it seems that the Anode Electrode would not float after the event and would go back to its intended 20kV.
Or is the diode unnecessary in this circuit and just the MOV is needed?
Most of the research I've done says that MOVs, TVS, or thyristors are used for crowbars or clamping circuits (apart from one source which says a series diode can be used: **broken link removed**
The series diode would definitely have a large forward voltage drop if they are rated to kilovolts, which is not desirable.
