If you are looking for a over temperature circuit you can try the TC621C chip of Microchip. Its very simple to program the temperature, just some resistors. look the datasheet.
Histeresis is always used to prevent oscillations ..
In your circuit, depnding on values of other components, ≈1MΩ - 10MΩ resistor between compartor output and (+) input can be used to implement small histeresis .. and ensure stability ..
I had already designed the comparator with hysteresis on the main signal path.
Only one side hysteresis is a good approach.( insert hysteresis into uninformation action active)
Hysteresis is a good solution to prevent from chattering.
Now I wondering about inserting hyteresis in OTP.
OTP is a indepenant block.
if OTP is active, I will turn off the bandgap reference and chip Reset signal active.
Could anyone tell me which is right?
( Hysteresis or Not hysteresis )
The purpose of using OTP is protection of Power MOSFET in my design.
I have not yet decided exactly that how to protect the internal circuit and turn on sequence and turn off sequence.
You can use this small design with hysteresis, and you can change the R1, R2 and R3 values, but it's not recomended the use of resistors with a value very high like MΩ.
If you don't use hysteresis, at the point of transation, the system stays instable.
So we must design a thermal loop, if we want the circuit to become active again once the temp falls down.
I was designing a Li-Ion battery charger and did implement the same concept their.
But did not shutdown the system, rather the current through the power mos was reduced or controlled by the thermal loop.
Dear Y C Park,
Could u eleborate more please.
As lastdance has suggested u would also like your circuit to become active again once the temperature has gone below the threshold value.
We would need some way of sensing the same on chip. Easiest would be voltage across a diode with a fixed current source pumping current into it. This could be compared with reference voltage. (buffer BGR, have a voltage drop across string of resistor). The comparator must have internal hystersis.
