mindthomas
Member level 4
Hi Breg.Hello Thomas
I have been planning to use the ov7670 with STM32F4 and was looking in for some reference source while I found your thread.
I took the liberty to download your code from the link you provided and have adapted it to be used with gcc and gcc makefile in a Linux environment.
This is going well for the moment even though I haven't reach goal yet, started yesterday, but I just wondered if you ever solved your problem above and if your reference code linked above is more or less outdated...
A few minor itches and compiler complains though. When you include header files, make sure to use same upper/lower-case in include prep. as in the real filename. Else they will not be found in a NIX environment which sees them as two different files. I know M$ don't care, but its good to be consequent .
breg
#include "SSD2119_api.h"
// Local declarations
void RefreshImage(void);
In this project I am going to use the STM32 so it was great that a source was already available.
Hi i have same problem
If you solved, could you please let me know?
