Outting 2 parallel resistor instead of a single resistor
bouchy
Full Member level 1
USA
Resistor layout
Hi All,
is there any advange in outting 2 parallel resistor insted of single resistor?
Thanks
Re: Resistor layout
If you have the resistance max power of 0.25W, substituting by 2 in parallel of the same max power will give you the ability of doubling the possible output power if it were limited by this resistance
    bouchy
