maria khan
Newbie level 3
i want to see the output voltage of LM35 with temperature increas in proteus ISIS....
would anyone plzzzzzzzzzzz help me....???
Try this. If you just want to see the output voltage, connect a voltmeter between Vout(2nd Pin) and the GND(3rd Pin). Then 1st pin to 5V DC. As you increase temperature from 0to150 Deg, you can see the voltage increasing from 0-1.5V on The voltmeter. To increase the temperature use the arrow signs on the LM35 in Proteus.i want to see the output voltage of LM35 with temperature increas in proteus ISIS....
