output the CLK on an external mcu pin
mariuszoll
Member level 5
I use on my project a STM8S207K8 mcu from ST, I configured the internal oscillator, HSI to work at 16Mhz. I use IAR embedded workbench.
I want to output the CLK signal on an external CCO pin.
Could you help me please how to do it? Since now I haven't work with STM8S mcus.
Thank you in advance.
I found that I have to set the OPT bit from the FLASH_CR2 register in order to have access to option bytes, but how to set AFR2, I haven't found yet.
