output impendence of CMOS
ashad
Full Member level 6
Full Member level 6
Trento, Italy
www.elabsp.com
hi,
i want to ask that what is the output impendence of CMOS on power off condition.
problem is that i connected two buffer out together one on at one time so if one buffer on the off buffer started to sink the currrent.
i am using CMOS output buffers
please help me in this regard
thanks
What you mean CMOS buffer. Does it has high impedance in OFF state?
i am using 74ACT245 having CMOs output...
i want to ask, typically what is the output impeadence of CMOS circuit during off state.
CMOS has 2 FET's in the output, one P-FET and one N-FET. When both are off there is a high impedance off state. When the P-FET is conducting you see the Vdd (+V) value on the output. When the N-FET is conducting you see the Vss (Gnd) value on the output.
So when the CMOS output is logical 0, its really at Vss or Ground. This a current sink for some circuits. When your output is logical 1, it's at Vdd level or +V of the device. This is a current source state for some circuits.
If your CMOS device does not have a high-impedance control pin then your CMOS output will be at +V or Ground at all times. Typically, this is a couple hundred ohms. See these notes by Texas Instruments:
https://focus.ti.com/lit/an/scha004/scha004.pdf
I see that the device you listed has 3-state capability but the datasheet does not give much detail about how much impedance is high-impedance. This might be available in another datasheet or CMOS reference.
I found it.... it's Ioz = 5.5V/5uA = 1.1Mohms. This is the mimimum impedance and can be more. Another datasheet shows 2.2Mohms.
Here is some helpful information when connecting 3-state devices:
