ouptut power of a mobile phone ?
laseetha
Member level 4
Member level 4
hi,
how much output power is needed during transmission for a mobile phone ?
i was told that it is 0.5 w from BSNL(Bharat Sanchar Nigham Limited) in Tamil nadu, India.
anybody can give other ideas
hello
i m not sure about it but as transmission is at very high freq the power should be in micro or milli watts. not in the watts.
well still i m not sure...keep searching. i will too. if i will get then i inform you...
best luck
bye
    laseetha
GSM Mobile phones have 2W max. output power.
This power is variable depending on phone-base station distance.Mobile phone would adjust the output power regarding to received BER level.
    laseetha
can i get any data seet regarding this
Actually it depends on the standard used. The max. output power depends on the MS power class. In GMS900, most of phones are power class 4 and transmit 33dBm (2W) while they are class 1 in DCS1800 and transmit 30dBm (1W).
For more data, check the 3GPP site in the section specification download. look for 51.010.
Hope that helps.
Added after 34 minutes:
hello again,
It is better to check TS05.05 at the following link:
https://www.3gpp.org/FTP/Specs/html-info/0505.htm.
You should find easily the different power class and corresponding max. output power vs freq. band.
Hope this help.
RFCMOS
    laseetha
usually the TX output will be about -6 to -7dBm and thru PA's gain .the maximum output power at the antenna will reach to 33dBm
I use to work for the Nextel Cell Phone company back in 2000. I was told that the tansmit power is .5Watts for the cell phone. The base station radio transceiver was around 70 Watts. I never questioned it to be false I just trusted in the fact that my superiors knew what they were talking about
    laseetha
For the mobile phone it is between 0.5W to 2 W
but for the base transceiver station it depent on the design so it varys between 60w to 100W in spicial cases
    laseetha
