Other lower frequencies for a Crystal
eedac
Junior Member level 3
HK
I used a FM audio transmission IC. A 7.6MHz crystal clocks the system and to be divided as a 19kHz-pilot.
But I found some other lower frequencies (600Hz, and 1kHz) accompanied with the pilot. It is generated from the crystal.
I tried to change the caps between the crystal and ground, frequencies would exist......what's go on? do any idea?
Thanks!!
