borodenkov
Full Member level 2
Hi all!
I've got a folded-cascode OTA with SC CMFB and wanted to look at its output noise. The clock sampling frequency is 64MHz, input signal bandwidth - 2MHz. I used PSS (beat freq 64MHz, 0 output harmonics) and PNOISE (1Hz-32MHz, maxsideband=30, no input noise source) for it.
The results that I am getting are quite suprising:
The output noise is 6mV/sqrt(Hz) at 1Hz, then it quickly goes down. I plotted both x and y axis in log scale. There is a noise pole somewhere around 100kHz.
I would expected that there should be a folding point where the flicker noise is equal to thermal - but I can't see it.
Also 6mV/sqrt(Hz) at 1Hz seems to be too huge!
Has anyone got any ideas about it?
Also if I would like to calculate the total noise - until which frequency is reasonable (signal_bandwidth, signal_bandwidth*2, sampling_freq)?
Regards, Alex
Regards, Alex
