OT: What is Roamer good for?
dz99
Member level 5
Member level 5
Between East and West Europe
Hello All!
This question is lead out from the electrons world, to the mechanical engineer's area.
Buy the way! Any one ones what is a roamer used to?
To give a better roundness a hole, or give a better surface a hole, or to drill a stack of hole, or to decrase stress in forged material?
Some thing familiar.
It's important.
Thank you!
Excuse me for the of topic;)
A reamer makes a hole to a tighter tolerance than a drill. It has more flutes than a drill and they don't spiral around. Also, it doesn't have a cutting face, it can only enlarge a hole.
If you need to press fit a bearing into a hole you will want to use a reamer on a slightly undersize drilled hole.
    dz99
