OSEK Operating System
Akramin84
Newbie level 6
Newbie level 6
osek operating system
hello,im doing RTOS which conplaint to osek using fujitsu microcontroller .i want to know whether the source code RTOS files and the implementation oil file is the same for all microcontroller ? i got these files file for 8051 microprocessor but i dont really sure whether it work with fujitsu microcontroller ? your help is really appreaciated.....
osek source code
Low level driver files are always microcontroller specific. For example the files which makes use of system timer used by the scheduler. Also the OIL file compiler are different.
thank you for the reply...do i need to configure myself of implementation definition part of oil file ?
.oil file + osek
Yes, OIL file basically contains configuration of tasks you need in your application. You need to modify it manually or using tools like OSEKWorks Configurator.
