Try and verify the accuracy of your model by extracting parameters yourself and compare with published parameters. I have done many osc designs with ADS and the measured results most of the time agrees closely with the simulated results provided the model is accurate. You should also try and verify with another simulator. I often use Ansoft Designer to do this.
