d123
Advanced Member level 5
Am learning a little about SEPICs, the attached circuit is a 2MHz oscillator for the PWM. Question is why does the frequency change from 2MHz at CD4049 output to 6MHz at MOSFET output, then goes back to 2MHz at triangle wave generator output?
The same thing happened when the P-Channel MOSFET was connected to an NMOS at a previous stage of experimenting, done to understand a few things about buffering the oscillator/crystal (reason for three inverters in series).
Thanks for any input.
