Oscillator Design In ADS software
BatuhanCan
Newbie
Newbie level 2
asdsadas
This is my oscillator circuit to be honest I am just trying to making an oscillator for my graduation project it has to be 1.7GHz because my friend's amplifier is working with 1.7GHz the issue that I am facing here I matched the circuit to 50ohm load but the output wave's amplitude is very low around mV's or less how can I increase my peak-to-peak amplitute of output voltage. Thank you for anyhelp that u can provide me, I am apreciated. And there is some issues about my transient simulation 1.7GHz has to have around 0.6ns period how should I arrange my transient inputs what should it's start time-stop time and max time step because when I try to obtain more information about waveform the simulation is taking so long whenever I try to simulate it in a hallow range it is just not usefull.
My final projet's aim to harvest rf/microwave combine it with solar panel store it'S energy in supercapacitor then after turning this DC into AC form with the help of oscillator then amplifying signal with an amplifier send it to another antenna to power couple of wireless sensors.
--- Updated ---
@BigBoss if you can help me I would be really appreciated. When I was looking around the form page to page I see that you have a lot of knowledge about oscillators.
To give some kind of reply...
Here's a version about the same from an article (a navy radio manual as I recall), not too different from your long-tail pair oscillator. It contains one LC tank. LC values are adjusted to yield 1.7 GHz. It works in simulation but no guarantee it works in real life.
The tail resistor is 50 ohms to show that value is operating somewhere in the circuit. Output is less than 1V. This circuit can be revised to adapt to your own circuitry.
Thank you for kindness to give me a reply. I will try to simulate this circuit and try to adapt it to our module. Meanwhile I will be still waiting for other advices from other users to share their ideas with me.
Your design steps are wrong buddy. You should follow the design steps one by one.
You have to check first that this circuit creates a sufficient negative resistance or not. Like this..
The Negative Resistance/Conductance is found by function of Tail Current
Then you add necessary elements to make sure the oscillator works healthy. For more information see ADS Help
Use also Nyquist Criteria for better observing the necessary and sufficient conditions.
The you obtain "preliminary/draft" results.
After all you may consider Matching, Harmonic Suppression, Pulling, Pushing etc. when the oscillator works under all circumstances.
You will have a long road to run. Practical measurements might make you surprised. Oscillator design is an Art.
LaTeX Commands Quick-Menu:
