I don't understand your answer. The shown error meassage isn't related to different ground symbols. Ground "0" should be fine.I mean the grounds are the same in this circuit. There are several types of ground in OrCAD. I have tried all of them (not for unconnected pins) but nothing changed. These unconnected pins are not grounded as u see.
The message says that have you pins unconnected that must not be floating. A straightforward way to handle it would be to connect the current limiter pins according to the datasheet suggestions.
"I have done everything you told me."
I am trying REALLY HARD to not question your intelligence. I keep telling you that you have to connect something to your inputs, and you keep NOT DOING IT.
Connect something to +IN2 and -IN2, then come back and ask some questions.
