dkace
Full Member level 6
I am trying to simulate a circuit and it a very important parameter is the power disippation ( and the current) on the load. I noticed that I have completely different readouts when I put 100k for the load resistor and 0.1M . In any case M makes big differece with k even if the value is practically the same.
Has anyone encountered the same problem? How did you solved it and which reading is to be trusted?
D.
D.
