OrCAD simulation of 74ac14 hex-schmitt trigger
kicom
Junior Member level 1
Hi
I tried implementing a schmitt trigger oscillator using orcad 9.
But it does not show the any waveform.just a dc of supply voltage at output
Why is that???
This is my circuit diagram
Hi
Why is that???
Hello, all right
I did the same circuit using Orcad 16.6 and got the waveform simulation in Orcad
eletmoraes;1397594I did the same circuit using Orcad 16.6 and got the waveform simulation in Orcad[/QUOTE said:
Your circuit produced an output high of +6V when it had a +5V supply??
I suspect that the original OrCAD used did not know anything about the 74AC14 IC.
Remove the short circuit from the inverter output to GND, and your circuit should (may) work.
