planet69
Member level 2
orcad pspice simulation
I wanted to simulate this circuit using Orcad PSpice but it just keeps on giving this error.
the errors are referring to the green lines. i don't know what's wrong, the lines are properly connected/drawn. the same problem still persist even if i use different capacitor models from different libraries.
if i remove the capacitors no error is generated.
the Vcc (12.57) is taken from a Vdc source
hope someone can point out my mistake here.
**** RESUMING tps.cir ****
.END
* D:\Orcad\pspice_ps\power supply-PSpiceFiles\SCHEMATIC1\tps\tps.stl written on Fri Sep 05 11:19:25 2008
* by Stimulus Editor -- Serial Number: 1239236 -- Version 16.0.0
;!Stimulus Get
;! SINE Analog
;!Ok
;!Plot Axis_Settings
;!Xrange 0s 60ms
;!Yrange 900m 1.1
;!AutoUniverse
;!XminRes 1ns
;!YminRes 1n
;!Ok
.STIMULUS SINE SIN( 1 100m 50 0 0 0 )
[b]ERROR -- Node N5988531 is floating
ERROR -- Node N5990395 is floating
ERROR -- Node N5989852 is floating[/b]
