Orcad or PCAD which is the best
Vonn
Full Member level 4
Full Member level 4
orcad schematic to pcad layout
i have a chance to have a course in PCAD or ORCAD ..
what do you suggest
which is the best tool
pcad compatibility
read through this
pspice pcad
Orcad is good...
And if you want to handle PCB then use POWERPCB than PCAD.
Best or good cad does not exist.
My points are as follows
- Tool is prooved ?
- What is spread in field broadly.
- Tool chain
Many people use orcad.
---> You can save time to make library.
Because the possiblity is vey high to get similiar schematic file.
(just modify....)
If you want to import PCB net.
---> Your choice is orcad or native schemati program.
example : powerlogic and powerpcb
orcad capture and orcad layout
Many people say PCAD pcb is good.
But tool is tool. my friend has used orcad pcb. He has not any problem.
I use powerpcb and also no problem
If you use pcad then it will be your choice.
Select one and try it, no more thinking.
best orcad
Orcad for schematic + layout+spice, but Pcad is good too for layout
I agreed with year choose 1 you feel good with and stick with it
pcad microvia forum
In my opinion, ORCAD and Specctra Autorouter is the best Electronics CAD's!
gorkin
gorkin@bol.com.br
orcad или pcad
P-cad is the best,:) but very best cad is that you know beter than other
better than allegro pcb
I use Orc@d, Expensive but very good.
what to choose orcad pcad
Orcad is the best.
orcad is easy to learn?
if u only for pcb design,pcad is better to do.
orcad is better in sim,sche design,but bad in pcb!!!!
pcad 2002 shape router
Orcad is better than Pcad,but The Allegro is better than OrCad,and Zuken's CR5000 better than Allegro...
pcad 2003 günstig
Orcad is a good start.
I would learn Orcad first, That's my opinion!
pcad or eagle
PCAD for complex design & Stability.
OrCAD for easy design & compatibility.
Regards. :)
best cad orcad layout
What about cadstar and pads 5.0?
Thanks
Thanks
Damned expensive! :lol:
You better use PROTEL99SE !!
Protel :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
For schematics Orcad Capture, for PCB design Allegro and for simulation Pspice.
Best Regards
IMHO, orcad is fully integrated tools, but both orcad and pcad are not evolutionaly systems - Caddence have allegro, altium have protel - this products more progressive...
PCAD is very nice ,easy to learn 7-10 days to autoroute
bye
