orcad not generated tap file
M.haris
Newbie level 3
Newbie level 3
After running the post-processor in orcad layout, i can't find the *.tap file. please help me to solve this issue.
thank you,
i could not understand your question.did u miss any option tab or let me explain what is *.tap file ??
actually I am using dip and and smd package components ,when I try to generate gerber file all files are generated but "THRUHOLE.tap" file not genertaed
The "tap" file is the drill file. Do you have post processing enabled for all layers that have holes? You may need to also have the drill drawing enabled in post processing but I doubt that.
yes i enabled in post processor setting
