Orcad Netlist Error Messages
jmillerjr
Newbie level 1
Newbie level 1
I get the following message from generating a netlist. Does anyone have a solution for this message?
Error: Integer value 1725077 can not be written in columns 28-33 on line 207.
Error: Integer value 1153585 can not be written in columns 44-49 on line 214.
Error: Integer value 1150372 can not be written in columns 44-49 on line 215.
Error: Integer value 1147775 can not be written in columns 44-49 on line 216.
Error: Integer value 1145082 can not be written in columns 44-49 on line 217.
Error: Integer value 1150430 can not be written in columns 44-49 on line 223.
Error: Integer value 1147775 can not be written in columns 44-49 on line 224.
Error: Integer value 1153028 can not be written in columns 44-49 on line 225.
Error: Integer value 1147775 can not be written in columns 44-49 on line 237.
Error: Integer value 1150430 can not be written in columns 44-49 on line 238.
Error: Integer value 1147775 can not be written in columns 44-49 on line 239.
Error: Integer value 1150372 can not be written in columns 44-49 on line 240.
Error: Integer value 1153585 can not be written in columns 44-49 on line 241.
Error: Integer value 1159903 can not be written in columns 44-49 on line 242.
Error: Integer value 1171298 can not be written in columns 44-49 on line 243.
Error: Integer value 1181753 can not be written in columns 44-49 on line 244.
Error: Integer value 1156958 can not be written in columns 44-49 on line 245.
Error: Integer value 1166828 can not be written in columns 44-49 on line 246.
Error: Integer value 1157092 can not be written in columns 44-49 on line 247.
Error: Integer value 1181753 can not be written in columns 44-49 on line 257.
Error: Integer value 1163066 can not be written in columns 44-49 on line 258.
Error: Integer value 1159862 can not be written in columns 44-49 on line 259.
Error: Integer value 1163038 can not be written in columns 44-49 on line 260.
Error: Integer value 1168076 can not be written in columns 44-49 on line 261.
Error: Further integer value errors suppressed.
SUMMARY:
Errors: 54
Warnings: 7
Info: Most likely cause of "Integer value" errors are:
- (Most likely) Coordinates in the database exceed IPC's coordinate system.
Try setting the database origin to center the design to reduce the large
coordinate values.
- Large pad sizes. Reduce any large pad sizes.
Thank you,
John
Which design tool you create your netlist for?
