ArakelTheDragon
Member level 3
Only 1 of the threads was a double post, please leave this one!
I am trying to create footprints in Eco Layout.
I want to know after I change the units to "mm", what do I see down left? Is 1000 = 1mm or 100 = 1mm?
This part is solved!
When I make the PIC footprint, I made the pins rectangles, but there is a distance from the outline to the pin, is that ok, should I make the pins round?
How much should be the soldering part on layers top and bottom? I put 40-50% more, meaning 0.150 for the drill layers whole and 0.300 for the top and bottom layers. If .150 is 1.5mm than its good I guess? If the pin is maximum 0.55mm in the datasheet, is 0.6 enough or 0.5? Is this available somewhere in the datasheet, 110 pages are a little too much for just checking. Normally they give it 1square mm of cable for 10A current as far as I remember, are there any rulles that I should follow, 1mm of soldering for 10A current?
How to autoroute in Layout, I only have the manual option, the rest is greyed out?
How to autoplace in Layout?
Thank you for the help in advance!
I made a PIC12 footprint but in the datasheet on page 94 I see the note that pin 1 should be under the scratched zone and that means under the processor?
