Orcad Layout 9.0 Gerber File Problem
Rich103
I am using Orcad Layout 9.0 and am having difficulty generating inner layer gerber files. The board is 12 layers and I am using free track obstacles to form a coil. I run the post processor and the gerber inner layers do not show the obstacles. What can I be doing wrong?
You are using OrCAd layout demo by any chance if yes,then you need to get it licensed to run post processor for so many layers.
Also if not, then go to -->options-->Post process settings and check if all layers are enabled for post processing,if not pls do so by clicking on the column and then clicking the yes option.
