Orcad Capture Warning: [DBO3885]
prathamesh.pokale
Newbie level 1
Newbie level 1
Hi all,
I am using Orcad Capture 16.2.
I have recently come across following Warning. (Green inverted triangle appears on schematic page). WARNING: [DBO3885] leading or trailing spaces found on net name or alias.
Has anybody came across this error?? What does it means? I checked for net shorting but its OK. Please reply if you know.
Thanks in advance.
check your schematic completely. If its fine do the following.
Copy the entire schematic into a new work space and try simulating. Let me know if u could succeed with it. Also check whether voltage/current markers are properly placed.
Try to take the snap shot n upload it if there is a problem still.
Surely i can help u in solving this issue. i too got such error long back. Its easy to come out of it.
