OrCAD Capture: How to use Bus instead of Wires
gurpreet312
Member level 2
Member level 2
orcad bus
Hello Sir,
I am using Bus (group of 8 wires) instead of wire in OrCAD Capture.
I have Given name by net Alias Q0 to Q7 on both sides
But have Not given name of Bus i.e. Q(0..7)
How to give that name Q(0..7)?
How to eliminate following Error?
I have seen
ERROR: Net Has Fewer than two Connections N38722.
Thankyou
Gurpreet
bus orcad
The name of bus must be givven in square braces, as follows: Q[0..7]
Added after 6 minutes:
The error "Net has fewer than 2 connections" means you have a pin with net connected only to it (i.e. 0 lenght). Find the net and see why you are not connected it (to find the net you can use its coordinates - they are given in rounded braces after the error explanation).
check bus width mismatch
How to name a BUS?
How to use BUS instead of multiple wires ?
Could any body suggest me?
bus in orcad
Ya already tried. But i DRC Error showing like below :
* Design Rules Check
Checking Pins and Pin Connections
Checking Schematic: SCHEMATIC1
Checking Electrical Rules
WARNING [DRC0005] Unconnected pin U1,C VOL: SCHEMATIC1, PAGE1 (5.70, 3.10)
WARNING [DRC0005] Unconnected pin U1,T\R\I\G\: SCHEMATIC1, PAGE1 (4.20, 2.90)
WARNING [DRC0005] Unconnected pin U1,THRES: SCHEMATIC1, PAGE1 (5.70, 3.00)
WARNING [DRC0005] Unconnected pin U1,R\S\T\: SCHEMATIC1, PAGE1 (4.20, 3.10)
Checking for Unconnected Nets
WARNING [DRC0006] Net has fewer than two connections N000603: SCHEMATIC1, PAGE1 (0.00, 0.00)
WARNING [DRC0006] Net has fewer than two connections VCC: SCHEMATIC1, PAGE1 (5.70, 2.80)
ERROR [DRC0029] Bus has no name and therefore defines no signals. N00219: SCHEMATIC1, PAGE1 (4.10, 2.70)
Checking for Invalid References
Checking for Duplicate References
Check Bus width mismatch
bus has no name and therefore defines no signals.
Hi
net has fewer than two connections
goktug said:
Hi Thanks,
Theses Q1,Q2,Q3... Q7 are the netalias or any other name?
