Basil
Member level 5
partocc
I get this error when trying to import properties
I'm using Orcad Capture 9.2
The beggining of my .EXP file is
Any CLUE to solve this problem???
Regarding to error message "ERROR [IMP0021] (Line 177) Occurrence not found" Which is the line 1 in the .EXP file???, The one with the project (.DSN) path and name file???.
Added after 2 hours 23 minutes:
I've discovered some issues...
Line #1 is the line with the file name, i.e. "DESIGN C:\DOCUMENTS AND..." below.
Moving rows in the .EXP file I was able to identify one of the lines what caused the problem. It's in the 4th line
Then I made a new EXP file and I got
SO: the problem seems to be something has changed the "HEADER" and the "ID" values (5421 instead 7869) in my IMPORT_this.EXP (it has lot of this values changed :evil: )
Export Settings I'm using
* Beginning Import/Export Properties
ERROR [IMP0010] (Line 177) Unrecognized object type or object not found; must be one of PARTINST,PININST,PARTOCC,PINOCC,FLATNET,SYMBOL,PIN,PART,PACKAGE
DESIGN C:\DOCUMENTS AND SETTINGS\CAMPB\Cambric_Age_probe.DSN
HEADER ID Part Reference Value PCB Footprint 1ST PART FIELD Manufacturer Notes
PARTOCC:6495 6495 R1 10 <null> 1% 100ppm 1/4W. Metal Film <null> <null>
PARTOCC:5896 5896 R4 10 <null> 5% 2W Carbon <null> <null>
PARTOCC:7075 7075 R43 10 <null> 1% 100ppm 1/4W. Metal Film <null> <null>
DESIGN C:\DOCUMENTS AND SETTINGS\ORCAD\PRECambricProbe.DSN
PARTOCC:6066 6066 D1 3V3 <null> ZENER 400MW MOTOROLA <null> <null>
PARTOCC:7869 7869 C21 30nF 1206 2KV 10% X7R - HIGH RELIABILITY Novacap 3333B303K202NHM
PARTOCC:2725 2725 R110 30K <null> <null> <null> <null>
PARTOCC:7913 7913 C24 30nF 1206 "2KV 10% X7R - HIGH RELIABILITY" Novacap 3333B303K202NHM
PARTOCC:1970 1970 C64 30pF C0805 50V 2% 30ppm/°C Kemet Electronics C0805Z300G5GAH
PARTOCC:5421 5421 C21 30nF 1206 2KV 10% X7R - HIGH RELIABILITY Novacap 3333B303K202NHM
