Orcad capture cis error [net0016]
chuzkin
Junior Member level 2
Hi everybody.
I am making a schematic in capture cis but when i run BOM, the following error appears:
ERROR [NET0016] There is no association for file %s. Configure this in the File Manager.
BOM Done.
Also, when I double click any part in schematic (to access PROPERTY EDITOR), and then try to close with X at the up right corner, the following message appears:
ORCAD CAPTURE
DENIED ACCESS TO A UNNAMED FILE
And when trying to close CAPTURE CIS, the same message appears repeteadly and can not close (I hace to force using task manager).
Version is ORCAD 9.0
Best regards.
BOM Done.
I got this same error. All I did was go to the directory where you told OrCAD to save your .bom file, select it, go to Properties, and change its Opens with program to WordPad. It still doesn't open up directly for me when I select the View Output option in OrCAD, but this way you can still view your BOM.
BTW, you can also open it with NotePad as well.
Sorry that I can't help you with your other issue. Good luck!
