OrCAD 7 segment display
castravete
Newbie level 1
Newbie level 1
Hello, I'm looking for a 7 segment display to make the following circuit:
Can someone please help me with this ? I have no idea how to make it myself and the rest of the components are in the library.
The circuit is a simple logic tester.
It would be good for it to be in .olb format because I have tried to convert some different files and it didn't work. I'm a beginner.
Thanks.
If you can't get someone to give you this component, then I guess you'll have to read the documentation about creating a component in Orcad. It is a useful skill, and not that hard.
--'Give a man an OrCad component, and he'll be able to design one circuit. Teach him how to create a component, and he'll design thousands.'
It looks as though the digit is connected so that only a few segments light. There is nothing wrong with doing this, but since you say it is a simple logic tester, you may as well substitute individual LED's.
Maybe green for 1?
Red for 0?
Rapid pulses will cause both to be dimly lit.
I once dismantled a seven-segment display. I found 7 tiny LED's, shining onto 7 translucent windows.
Maybe green for 1?
Red for 0?
Maybe I'm wrong, but I think the OP is looking for a OrCad schematic symbol, not an actual 7-segment display.
