Eshal
Advanced Member level 1
- Joined
- Aug 29, 2012
- Messages
- 470
- Helped
- 16
- Reputation
- 32
- Reaction score
- 15
- Trophy points
- 1,298
- Location
- Nowhere :)
- Activity points
- 5,149
How are you all?
Experts my problem is regarding with Orcad 16.6. I have lite version.
I have a practical from digital electronics in which I am using flip flop, the edge triggered J K flip flop.
Can you tell which is the square wave generator to give the clock to the J K flip flop? I am using Vpulse. But I don't know how to set frequency in it. I want to use 1KHz and 5Vp-p. And there are several more parameters which I don't know. What should be V1, V2. V1=0v and V2=5v. Is it?
What is TD and should I put in the value of TD?
What is TR and should I put in the value of TR?
What is TF and should I put in the value of TF?
PW is the pulse width but should I put in the value of PW?
What is PER and should I put in the value of PER?
Where is frequency parameter?
And why doesn't my simulation button able to press? It can't be press. What should I do to press it?
The picture is also attached below. There are two J K flip flops are shown. Which one should I use? In the experiment I have given with 74LS76 but 7476 seems same as 74LS76. And where is the Vcc pin and GND pin in it? How to supply Vcc and GND to the IC?
![Orcad.PNG Orcad.PNG](https://www.edaboard.com/data/attachments/30/30109-5e4b6b7f773de3282b308a87e620188d.jpg)
Thank you sir.
Thank you sir.
