Optimizing C code to replace % and /
tectona
Member level 2
Member level 2
Hi all,
I need ur help to Optimize C code.
I want to know how replace "%" & "/" in C.
In my application I use this two function for finding Reminder & Quotient.
Like
6505/1000 = 6
6505 % 1000 = 505
Plz, give me good logic so I optimize my code
Thanks in advance.........
Regards
Tectona
Re: Optimize C Code
"%" & "/" is legal arithmatic operator in C, why to replace it?
Optimize C Code
division with power of 2 is simple by left shift
example
6505 / 16
6505>>4
6505 / 1000 = (6505 >> 3)/125
Re: Optimize C Code
Hi, Do not try to optimize this. In most C compilers I know this is done very very efficiently. Only a few asm instructions.
If you want to optimize:
Remove:
Multiply functions. unless the value is n^2 * X
Division functions. unless the value is X / n^2
all other math.
Try to replace them with AND or XOR.
Optimize inside loops.
Use look-up tables if possible. but do not use multi-dimentional array's try to stick with one dimension.
FOR: xxtigerxx
A good c-compiler will make the same code for.
X = 6500/16 and X = 6500>>4
Paul.
Optimize C Code
I'm guessing that your microcontroller has a slow division opcode, or none at all, and you don't like the code generated by your C compiler. Try searching the 'net for a better compiler, or search for a division algorithm optimized for your specific microcontroller and compiler.
Re: Optimize C Code
Thanks for ur support,
I required this optimization for reduce code memory & fast execution.
I use microchip 18f controller , in this controller there is no division instruction so compiler return their own routine for execution this basic arithmatic operation.
I use Hi-Tech PICC18 compiler.
I want know is there any method to findout result using + , - or >> , << , & , | .
Because i my divider is fix say 1000.
Thanks for ur support.
Regards
Tectona
Optimize C Code
if you are always dividing by 1000 try something like this:
/* Assume dividing a 32 bit number by 1000
    1000 is a 12 bit number */
#define shft (32 - 12)
int i;
int a = 1000 << shft;
int dividend = 6506;
int remainder = dividend;
int quotient = 0;
for(i = shft; i >= 0; i--)
   quotient <<= 1;
   if(remainder >= a)
      quotient++;
      remainder -= a;
   a >>= 1;
/* quotient and remainder are correct */
    tectona
Re: Optimize C Code
Hi jonw0224
I execute your code in C compiler(PICC 18) but this code cannot work.
Thanks for your support.
Regards
Tectona
Optimize C Code
jonw0224's code requires 32-bit int. Notice the "1000 << shft".
Maybe PICC has smaller int.
Optimize C Code
echo47,
thanks, using sizeof() would be more general.
-jonathan
Optimize C Code
xxtigerxx advice is good way to start. you can further suboptimise your code if :
- value of divisor is known and restricted in range
- try to change divider to power of 2 if you can and scale all data to that value, that will give you chance to use logical operations instead of arithmetical
- if seeking for alphanumeric conversion routines, look to bcd conversion routines
Yet , have a lok to book "Algorithms for programmers Ideasa and source codes". I think that is one of the best book on such optimisation subjects. Search google should be available for free , thanks to authors.
    tectona
